my mk1 golf will not idle!!
(In Topic #140317)
i have no idea wats up with it!
fuses are fine
all leads are on
got fuel
chokes working
how can i sort this? and fast
it will drive fine but when i stop at a junction clutch down with no accelerator it dies!!?
then other times it will be fine? any ideas?
fuses are fine
all leads are on
got fuel
chokes working
your idle screw on the carb needs adjusting
try turning it half a turn at a time
Bobby
surely its not though as it runs fine other times? i have no idea wat it could be!
could new plugs and leads sort this?
^note that reads IDLE screw, NOT mixture screw. The idle screw only affects mixture/throttle at idle - no difference once the revs rise.
Mine has just done exact same, replaced the rubber o ring on idle screw, and adjusted screw. Started back up, n touch wood never had it again. Cheap fix/ worth trying.
You will be surprised Lol. Simple engines, simple faults.
Re: my mk1 golf will not idle!!
fuses are fine
all leads are on
got fuel
chokes working
I am having the exact same problem, i just cannot get it to idle. Did you manage to sort the issue and if so what was it? I have had the carb apart numerous amounts of times now, these o rings? would these be included in a carb rebuild kit? if this is the case then this is surely the only option? i have replaced the flange between the carb and the manifold thinking there was a possible air leak. and made up a new gasket for the carb body so the only thing left to do now would be to buy a kit and just rebuild the carb?! Any Ideas?!!?!?!?! PLEASE! ha
O.Bendall
Oli, What carb have you got?
check your idle cut off valve is working correctly
Rusty Hookers Dub Club
Oh go on, I'll say it as well. There's an idle issue.
Or, there's a vacuum issue - check the vacuum diaphragm on the back of the distributor for functionality.
1983 Golf 1.3 Driver:
Happened with mine too!
I got a rebuild kit for the original carb (solex pict7)
changed all the diaphrams, o rings etc, cleaned everything out with a decent carb cleaner, changed the carb/intake gasket, and its been sweet ever since!
I think mine was mainly due to crap being inside the carb ( previous owner let her sit for ages so there were fuel crystals )
