my 1.1 c wants to move slightly faster with minimum spending
(In Topic #93958)
Just start off by making sure the basics are SPOT on.
Points gap, plugs gap, valve clearences, timing and mixture.
Make sure the exhaust isn't leaking anywhere ( and that you only have ONE silencer ! ) Also, ensure that the rubber boot the carb mounts to is TOTALLY leak free ( a lot of people chase their tales on that one. )
You can always fit an 4 into 1 Ashley manifold, that'll release a few HP and some bigger jets in the carb won't be much either.
Following that, you can pull the head off for some smoothing work and grind the valves in properly. Lots of the little easy things add up to a useful increase.
A lot of people might recommend that you just stick a 1300 HK code lump or MH lump from a polo or a golf in, which I/we have also done…pics below…
PM me if you want any more help/details
a pic of my mates 1.1……
Before -
During
During…….
Sometime after…
Real golfers don't play with clubs
how'bart putting a K&N Air filter to go with bigger jets..?
and change the 4X gear box to 5X to smooth ur ride.
Diresh
1975 VW Golf MK1 1100cc-Black
1979 VW Golf MK1 1500cc-Yellow
1982 VW Golf MK1 1600cc-Diamond Silver
1981 VW Rabbit 1800cc-Black
1978 Peugeot 504GL 1800cc-Torch Red
1995 Alfa Romeo 164TS 2000cc-Blue
1995 Fiat Coupe 2000ccTurbo-Rosso Red
