mk4 polo 1.4 running on mk1 1.3 gear box?
(In Topic #106084)
Thanks.
You need to add the seal extension and drive flange on the driverside. I've got the parts somewhere as I put a mk4 box on my mk1. The Polo might be cable change and the tapped holes may be missing on the casing.
Sound anyway mate
the engine will mount straight in no probs just make sure you have a mig handy for the gearbox mounts and alteration to the cambelt end mount :wink:
if you fitted the mk4 engine to the mk1 box you would need flywheel clutch ect to match the gearbox
Steve_Matthews said
Yes, it'll go straight on with no major headaches. Just bolt it up and away you go
lol nearly that simple …
As its a late multi port injection wont he also have to transfer
ECU
ECU loom
fuel pump
fuel lines
clocks
engine loom
fuse box
Ignition barrel and keys
And exhaust system??
Or can you use the 1.3 mk1 carbs and igntion timing??
Anyone care to go alittle deeper into what needs to be done
ECU
ECU loom
fuel pump
fuel lines
clocks
engine loom
fuse box
Just run it on the standard carb from the old engine - inlet manifold bolts straight up to the 1.4 head. No need to do any of the above.
You'll want a distributer and ignition amp from a late Mk2 Polo. Again, you can re-use the standard Mk1 exhaust and manifold, just bolts straight up.
The 1.4 lump is NOT a multipoint engine.
ECU
ECU loom
fuel pump
fuel lines
clocks
engine loom
fuse box
Cheer dude. But the 1.4 lump where talking about IS multipoint injection engine
