Mk1 golf 1.1 caliper retaining spring
(In Topic #137771)
hi,
was cleaning out the caliper and the retaining spring snaped,
has anyone got one for 1.1 brakes for sell please or no where i can get one?
ive got two old calipers if you want them
Bobby
hi, how much? cheers
free mate i think the passenger side sticks a little bit but drivers sides fine
Bobby
Wow thankyou very much! Where abouts do you live? Or could you post for a fee? As a work alot. Cheers again mate
walpole pe14 mate could post mate dont know how much that would cost
Bobby
PM'd you.
still in need of a "Mk1 golf 1.1 caliper retaining spring"
anyone?
anyone?
even if some has got just the spring, dont have to come with brakes…
Only need this last thing to pass MOT!
Does the 1.1 mk1 golf use the early ATE front calipers with the small square pads retained with two pins? If so they are the same as MK1 polo items and I have a full set of spares - this retaining spring you need, is it the retaining spring for the two pins that hold the pads in or the spreader spring that goes between the two pads (shaped like a cross)?
Exactly the same then, what spring do you need?
the one you can see on the right, holds the middle part in
I've never been able to remove that spring in the past, sure it's pressed in to the housing. I do have a bare caliper body complete with spring (no cylinder, etc) that's up for grabs if you wanted?
Can grab a picture if you wanted…
Someone must have one!
