MK1 Driver Problems (help Needed)
(In Topic #100398)
Need some help, i've got a 1272cc Driver and it's having serious problems idleing and its also heavy on fuel, heres whats its had done
recently to solve this problem but which have so far failed.
Full Carb rebuild.
Headgasket
and a coil
Plus all the usual service parts I,e.
Plugs, leads, dizzy cap, air filter, oil filter & oil.
If anyone has any suggestions please reply to this post
Thanks in advance
Wayne
teh rubber mount that goes between teh carb and teh inlet manifold
take the air box off and give teh carb a wobble, it should be nice and stiff rubber, spray dw40 around teh carb foot when idlling, an increase or decrease in revs = an air leak
The Carb Rebuild was done by gower & Lee but i don't think it could be that, but you never know, but i'll let the guys at the garage know about the carb foot, but if anyones got any more suggestions that post them up.
Wayne
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
Real golfers don't play with clubs
mk1john said
could be part of the autochoke system - perhaps a vacuum pipe not connected if you have fitted an aftermarket bolt on filter.
i thought the standard carb on a driver was a manual choke?
i would defo check the carb flange/foot there will also be a deposit of what looks like oil at the base of the carb if the flange is away.
Idling problem
Phataz1 said
Manual override fella
so they where all originally auto choke?! sorry to hijack the thread by the way….. how does the auto choke actually work might try and get it goin again?
Mk1 drivers are manual choke solex
Good carbs IMO.
I appreciate all your help with this, but i'v checked with the garage and the carb foot was fine i'll advise them of the inlet manifold gasket/ seal. but in the mean time if you have more ideas, post em up, every little helps.
Wayne
