inlet manifolds
(In Topic #120350)
inlet manifolds
i just need to know if a 1.1c inlet manifold will fit on the gt engine before i start ripping it apart
if someone can help me
what carbs are you going to fit? there are a number of different manifolds available to enable you to fit carbs to this engine.
Rusty Hookers Dub Club
im guessing your going to stick with downdraft as you wanted to reuse your old manifold. so you'll be either using single or twin choke. each has its own manifold. the gt engine uses a hydro head and a water heated manifold. these can be found on mk2 golf(small block) and loads of old polos(mk2). the polo manifolds are all single choke, but if you can find one some small block mk2 golf came with a twin choke carb. if you are simply using a vw carb then everything will bolt together nicely, but if you wish to replace with say a webber then you will need an adapter plate.
best thing to do is get down the scappies and bag 2 or 3 manifolds look for the carbed engines, there are literally dozens of polos getting scapped! and its the best place for them if you ask me!! and whilst your at it grab lots of coolant hoses, thermostat housings(theres quite a few variations!) and electrical connectors, and you'll need a mk2 golf(small block) dizzy and amp. i will try and remember which rad i ended up using.
hope this helps, its been a couple of years since i did my conversion!
martin
martinandhisgolf said
check out my for sale ad in engine and runing gear section, i have a few small block mk2 golf parts for sale including the mentioned inlet manifold, i also have a 2e carb to get you going and a distributor aswell if your interested once youve had a look at different things you need
martin
lol! thats the boy! the 2G flows pretty damn good! de hedgehog the heater (to improve flow) and leave disconnected. port match and clean up the runners for even better flow.
inlet manifold
anyway, you were on about removing the hedgehog from the manifold??? i have seen it there and left it unpluged and i was thinking about removing it but came unstuck when i realised how would i plug up the GAPING hole (might cause some lumpyness or the ocasional missfire???)
how would i go about plugging the hole up?? is it just a case of using a plate and sealing it on with gasket stuff and bolting through origional holes???
thanks !!
inlet manifold
thanks !!
Re: inlet manifold
shinny said
i have he exact set up as in that picture…..looks 100% identical to mine, right down to the facet solid state pump!!!
thanks !!
dude just dehedgehog it!!! stick it in a vice and cut the spikes off, file flat( top tip spray wd40 on your file to stop the alloy clogging it up) then pop it back in. polo boys do it all the time.
proper job!
inlet manifold
what else can i do. things like that add up so have you got any other mod's i can do like that??
inlet
would it also be a good idea to get a stainless exhaust manifold….i think there is some on ebay for about £200
and with the intake side, apparently some vauxhall manifolds fit and thy have weber carbs on too, is this true or would i have o look somwhere else ft one, coz i would like to go weber
inlet
