how 2 block the hole on bottom of inlet
(In Topic #95637)
g40'd ratter
<div><embed type="application/x-shockwave-flash" wmode="transparent" src="http://w139.photobucket.com/pbwidget.swf?pbwurl=http://w139.photobucket.com/albums/q312/Forgeman/75e604af.pbw" height="120"
thats what im getting my mate to do to mine then its off to the garage for mot !!!?!?!?!
Pics to illistrate
BiG_J said
It's alloy, so wont be easy to weld, ur best bet is to take the inlet off, clean out the hole (get rid of all the carbon) and then fill it up with J.B Weld, i did something similar, because im using a manifold of a polo with weber 32/34 carb the two exhaust ports on the head are useless and u have to cover them up, when my head was being rebuilt i filled the holes up with J.B weld on both ends inside the inlet port and exterior i then smoothed it off,
Pics to illistrate
Did you port and polish the head? And did you fit bigger valves? I wanted to do that,but i got a 1.8 engine. And i'm interested what is the limit for 1.3 head?
Sorry for offtopic!
2.0 16V
Port and polish was a home job, as for valves they're standard size, the black marking you see is the maximum circumference on the head gasket, if you compare my head with a standard head you would see the difference of the combustion chamber, i enlarged mine, i made it more round and curved around the corners for a better squish and to allow more room for the valves so they're not limited for space, no doubt thats lowerd compression but don't know by how how much.remus said
Pics to illistrate
Sorry for offtopic!
Here some pics after skim and valves inserted.
Grooves on head.
and ! WTF are those holes there for in the first place ?!
ta.
Real golfers don't play with clubs
Yep the engine is up and running with that head just fine, as for the JB welds it looks solid on the exterior but i cant really tell on whats going on the inside, worst case the jb weld will melt but no sign of it yet, theres no bits commin out the exhaust or anythin, but then again i havent driven it hard or anything, its still off road and i havent packed on any miles on it yet, i take it around the block once a while to see how the engine copes, so far so good.Gold-mk1 said
Question ! Have you run that head up yet ? How well is the JB holding ?
and ! WTH are those holes there for in the first place ?!
ta.
The holes are there to heat the manifold up using the exhaust gasses instead of water.
thanks martyn 8)
thanks martyn 8)
