Help my Search!
(In Topic #217852)
Hi Guys, really struggling to find this version of the 1.6 head anywhere! Found other heads but they all seem to have different little bits on. Anybody know if that makes a massive difference or can i buy it and just change parts, the photos attached are mine. If anybody has one going I'll gladly pay you for it! Thanks guys!
Sent from my G8141 using Tapatalk
Mk1cabAlex
Welcome to the club first of all. 😀
Well I can't this question for you but I will move your post into a section where you might get a slightly better response! 😉 👍🏼
Re:
Hi mate, thank you!Golf Cabrio said
Mk1cabAlex
I am currently unable to get in to any other topics as It states I have no permissions! I tried to post it in Engine and it would not let me! Thank you!
Mk1cabAlex
Well that has thrown me a curve ball.
As I'm on the move maybe I misread your post.
But first of all can you (if possible) log off this device and then log on to a different one? 🤔
Your Moderator Team
Sent from my Smartphone 📱
Re:
I believe it has been sorted now thank you though!Golf Cabrio said
Mk1cabAlex
Your Moderator Team
Mk1cabAlex
Your Moderator Team
Ok now that has thrown me another curve ball.
As you "believe it has all been sorted" can you please unlighten me as to how it's been fixed?
Because it will be of great benefit to me as a part time 'Admin' and hopefully for our members as well. 😎👍🏼
Your Moderator Manager
On the side of the head is a part number, if you clean it of grease, and then place the part number in a google search you may get quite a few hits.
049 103 373 ?
as in
https://www.ebay.com/p/VW-Volkswagen-Cylinder-Head-RARE-Water-Cooled-Carb-Rabbit-Golf-Scirocco-Mk1/1533552878?iid=222994449568&chn=ps
https://www.ebay.com/itm/Cylinder-Head-VW-Jetta-Rabbit-Scirocco-Mk1-Dasher-Quantum-Audi-049-103-373-B-/311856017086
049 103 373 ?
as in
Golf Cabrio, this is the wrong section…. The 1.6 is a big block carb engine, not a small block…. Don't worry to much about the numbers on the head, you need an early 1.6 carb solid tappet head, I guess upto 1983 ish as they changed to hydraulic tappets after that.Golf Cabrio said
Mk1cabAlex
Solid tappets have 5 caps, Hydraulic heads have 4 caps.
You might be able to fit a hydraulic head to a not hydraulic engine but not 100% sure, you would find lots of those and if you change/get the top water hose outlet you could fit the 1.8 head…..
1.6 water outlet between cyinders 1 and 2, 1.8 water outlet between 3 and 4.
You might find it easier to take the head to an engine builders and see if they can repair/fix it?
Last edit: by mark1gls
Help my Search!
Awesome thanks I'll check it out!
