got cambelt and water pump changed - not happy
(In Topic #146542)
it was a "gates" belt n pump kit and now the car whines like a b'stard, plus an annoying squeek.
i have checked the tension and it genuinely looks and feels fine.
i just can't live with it the way it is now. taking it back to garage tomorrow,
i ran it without the cambelt cover on and watched the inside face (where the teeth are) and every time the squeek happens
i can momentarily see the teeth, its like the belt is not going round in a constant speed if you know what i mean?
could this be a tooth out or timing issue?
i feel sick to my stomach going from a car i loved to drive about to one i cant stand in a couple of days.
i know (now) the gates belts have a bad rep for whine.
any advice before i put a match to the car?
-z
i pressed the little red button
there are quite a number of Google threads about noisy gates belts.
What about the squeek I mentioned?
Any ideas?
Thanks for replies.
The belt should twist to not far under 90 degrees for the correct tension.
Check it definitely is the cambelt and not the alternator belt by lightly powdering the alt belt with talc. Make sure the cover that covers the water pump is fitted correctly and not distorted/fouling.
If you are concerned about the timing it's real easy to check, just line up the line on the crank aux pulley to the 2nd notch in (tdc) on the pointer above crank pulley, the camshaft sprocket has a small dot which lines up with a finger at the bottom for the pully, it is actually part of the cover that covers the water pump.
Personally I think you should take it back to the garage and tell them the problem.
Its not your cars fault! don't disown her, instead, show her some affection and tell her how you feel for her in this time of stress and worry
it was waaaaaaaaaaaaaaay tight.
is there any other seal between pump and block apart from o-ring?
he loosend it slightly and some water came out. took some pressure off the pump pulley. and did it back up.
the noise is about 95% gone, i can live with whats left.
i wont be going back to that garage.
its so hard to find a decent garage/mechanic.
the last garage i was at when i got my focus st serviced couldn't find the 5th spark plug, seriously!
the one before that took it on a 14 mile "test drive"
-z
i hardly drove it (didn't want to) so i doubt it did much damage or ware, it looked ok when i looked at it today.
what a difference a wrongly tensioned belt can make. it wasn't just the noise, the whole feel and drive of the car was affected, not a nice feeling.
i'm up in inverness and slowly marking off places not to put my cars.
thanks for reply chaps.
