fuel problem on my 1.1 1976
(In Topic #127961)
Firstly, when you say fuel bubbles in the fuel filter - does it in any way seem that there is air entering the system at some point? - almost looks like fizzy petrol when it is in the fuel filter?? If so you could be having the same problem as me - Be careful with the braided pipes, its hard to know if they are really fuel pipes..
Secondly, if you throw a bit of petrol down the carb directly - try to fire her up (be patient) and she should run for about 30 seconds - just to check all your engine and stuffs is still working properly, that there is no blockages down there.. - its easier if you get someone to help you.. (dont drown the car though !)
Thirdly.. If you are still having problems, With the help of your friend again.. open up your fuel tank (from the access under the back seats - pretty annoying to remove but they do pop off like a paint tin !!) and you will find two metal tubes.. one thats drawing the petrol to the engine, and a return pipe. I managed to check these for blockages by getting my friend to blow down the pipes from the engine (behind the filter on the drawing line) and see if you can feel air.. you will know if you have a blockage - but deffo check all braided pipes..
Hope this helped
Georgie xx
Jon.
