Fuel injection on a 1.3 (GF code)
(In Topic #142354)
Only thing I'm "worried" about is the lower compression ratio of my engine compared to the Polo engine
Any thoughts???
But in all honesty I doubt you'd notice any difference between the two compression ratios
but yeah dont worry about the compression it should be fine. in fact im pretty sure CR is same on GF and MK3 polo 1.3, the power is the same. its only the GT that has higher compression and that is MPI
The GF is 10.0:1 with flat top pistons.
The 3F is 10.0:1 with bowled pistons and valve cut-outs. (polo GT MPI)
The MH is 9.5:1 (average later mk2 polo hydro engine).
I just fitted a polo 3F engine in my Mk1 with an MH inlet manifold and a Weber 32/34 DMTL out of a scirocco. Had to use a scirocco header tank with a mk3 polo thermostat housing and mk3 polo radiator with the 1.1 golf switch and fan. Its using the later flywheel, clutch and release bearing on the original 3D 4 speed box from the formel E. Idles sweet as a nut, had a firing issue above 3K, but on inspection im putting it down to a knackered rotor arm. Yet to try it down the road since, but it runs sweet on idle and when revved.
Personally i'd ditch the early meccy lump in favour of the hydro engine, if going injection. The inlets on the early engines have random pre-heat ports. The inlet and exhaust ports do physically match up on both types though.
So to conclude your GF "driver" engine has the same cr as the polo GT MPI engine.
Pretty sure thats incorrect matey, the compression ration is 8.2:1 on a GF.
All the later hydro engines ran a higher compression ratio, probably because they had better fuelling systems than the carb engines.
I fitted Polo GT injection onto my HH engine (identical to the GF) and I'm loving it 8) A couple of die hard polo lads have commented on how nippy it is, and considering it doesn't have the GT cam, gearbox and compression its quite impressive
The only aspect of fitting this injection to an early engine is you'll have to swap the cooling system for the polo too. Because you need the polo's water temp senders, you need the polo's thermostat housing. And it you have the polo thermo housing then you need all the corresponding pipework and have it routed the right way.
I managed to keep the GF/HH thermostat housing and made my own housing for the temp sender which I then welded on, but unless you have access to a lathe and an alloy welder then its not the best option.
Apart from that its very simple, wire in the fuel pump and ECU relays and the rest is self contained pretty much 8)
rubjonny said
what about the AAV lump, is that same as 3F or MH? also how is it the GT has so much more power than the 3F if the CR is the same, all in the cam?
AAV is the 1.3 SPI lump from mk2f polo's.
3F is the GT engine. 75 hp comes from having MPI I guess, the cam profiles are probably more agressive than the other engines.
If you meant why does the 3F have so much more power than the GF driver engine? Then i'd put that down to the injection and the GF having a shit weber solex carb. Also the cam proflie on the GF is probably suitable lame.
with the sensor issue does the old mk1 housign have an m10 or m14 thread? if so you can use early mk2 digi (m14) or abf (m10) ecu temp sensor. direct fit and will work with polo spi/mpi ecu
I'd put money on the GF compression ratio being 10.0:1. I dont have a mk1 golf haynes to hand though. Your HH lump was 8.2:1 which is almost lower than my G40's compression at 8.0:1!
Here's a handy table courtesy of Gaz on clubpolo.
rubjonny said
cool just wasnt sure im not a polo/small block expert.
I'm not sure what thread the mk1 housing has for the sensor but its a single pole sensor, and the polo 3F sensor has two poles but it isn't threaded. They are held in the housing with clips and sealed with an O ring so I'm not sure which other sensors might fit :dontknow:
The 3F engine has more power than the other polo engines mainly because of the cam and the injection. The cam has much more aggressive lift and duration, like visibly obvious differences when you look at it All the other aspects of the GT engine like the gearbox/compression etc all help to create a well set up little car, but they make minimal differences if they are absent 8)
The GF cam is actually the best factory cam you can get for the early engines, and is near enough the equivalent of the GT cam but suited to the design of the mechy head engines :wink:
Yeah Mr Anorak Sir, its been sopken about on Club Polo about how suitable the HH/GF engines are for forced induction due to the low compression ratio, but I think the general consensus was that they just aren't very strong engines so its not a great idea Thats why I gathered that the GF had the same ratio as the HH… I'm happy to be proved wrong though
I'm afraid I'll have to take your money fella I just check my Haynes and it says 8.2:1. Paypal is fine with me
basically it depends what holes the housing has got! obv one of them is taken up by the dash sender. im just not sure how the mk1 smallblock thermoswitches are fitted, if indeed they have any! the early big block carb mk1 thermoswitches are in a dody inline bracket thing
my post above about the cr was based on ETKA showing the GF and AAV lumps both having the same power, so i assumed CR was the same seeeee.
Aaah! Fail. Dunno where I got that idea then :roll:
Would you accept chocolate coins?
Sounds good to me!
Rubjonny you once again surpass your reputation for being a legend! 8) The mk1 thermo housing has one threaded hole which I think is M10, and that is where the single pole sensor for the dash normally fits. But it wouldn't be very difficult to just drill another hole and thread it to suit either of those sensors you mentioned! Saves all the crap that I did to fit the polo sensor :roll:
You can just see the little single pole sender on the upper face of the housing here, with the boss I made for the polo switch facing the camera:
