cylinder head compression readings not matching, mk1 golf 1
(In Topic #99440)
my neighbour lent me his comression tester.
the readings i got weren't the same for each cylinder
THE READINGS ARE MEASURED IN lb/in?
what does this mean has gone wrong?
….also…
if this is bad news, what other heads will go on? golf, polo, 1.3?
its a 1.1 GG
its a 1.1 GG
could be valves/valve clearances or worn piston rings in no 2.
Take the head off and check it or get it checked.
Replace rings if worn.
check valve toleraces first,
lumpy tick over??
pain to start when cold??
low MPG?
al can be causes from wrong valve tolerances
as a valve couldnt be closing propper = blow past the valve seat.
if these are ok,
the gasket could be gone, or even the valves need re lapping, so they seal propper.
if you go a head gasket, get it skimmed and valves re-lapped, and new stem seals
= happy days
lumpy tick over??
low MPG?
if these are ok,
= happy days
Do a leakdown test. It will show you where the gas is escaping.
my cylinder head cracked recently and caused similar problems......... worse case scenario though. have u over heated it recently?
