cylinder head compression readings not matching, mk1 golf 1
(In Topic #99440)
the readings i got weren't the same for each cylinder
THE READINGS ARE MEASURED IN lb/in?
what does this mean has gone wrong?
if this is bad news, what other heads will go on? golf, polo, 1.3?
its a 1.1 GG
Take the head off and check it or get it checked.
Replace rings if worn.
lumpy tick over??
pain to start when cold??
low MPG?
al can be causes from wrong valve tolerances
as a valve couldnt be closing propper = blow past the valve seat.
if these are ok,
the gasket could be gone, or even the valves need re lapping, so they seal propper.
if you go a head gasket, get it skimmed and valves re-lapped, and new stem seals
= happy days
