Crunchy 1.3 Driver Gearbox
(In Topic #107280)
My '83 1.3 Driver is VERY difficult to put into any gear. Reverse is almost not worth trying for, first and second are achievable but with lots of crunching and at speed fourth is also crunchy. All this has happened in one week as last week everything was fine.
As I don't know much about gearboxes I'm assuming that the synchromesh may have gone? Can anyone back this theory up?
The clutch is fine and bites halfway down the pedal travel so I don;t think there's any problems there.
Where do I go from here? Am I looking for a new gearbox or will it be easier to find a new engine & gearbox together?
All replies gratefully received!
The first suggestion would be to check the linkages - they can wear quite badly and if there's a lot of slack, you may not be pushing the selectors home far enough for them to engage fully. There's a replacement bush kit available from GSF for the lever end, although when I did my son's linkages, there was a vast amount of play at the gearbox end as well. Some deft hammering of the cage and packing out of the ball with cloth soaked in grease has made a massive difference.
Secondly, I'd change the oil for a good-quality replacement - it can make a staggering difference, especially when its cold.
Thirdly, you could try a gearbox additive like Slick 50 - some people swear by it, others swear AT it :roll:
Ours has done 150,000 miles, so they can last well
