can you run a 1.4 mk4 polo engine off mk1 1.3 carbs/igntion
(In Topic #106381)
once a mk4 1.4 polo engine has been bolted into a mk1 can you run it off the mk1 1.3 carb and ignition system?
Thanks Tom
Then with the 1.3 head you can use the standard mk1 carb and manifold, although the manifold may need modifying slightly to make fit.
The 1.4 polo head manifold mating surfaces would not allow for the mk1s carb manifold to bolt up properly, so a hydraulic 1.3 head of some sort is needed.
