can't get my 1.3 driver to fire! :'(
(In Topic #133669)
im not sure if it compression or something but i've changed the coil, leads, dizzy cap and rotor arm, condenser, plugs, taken the carb off and cleaned it, new battery, tried towing it and bumping it, it makes the noise of wanting to start while bumping it but as soon as you stop it just wont fire! dunno if it might be timing or something maybe?
please help me i need it running!! :cry:
thanks Rhys.
What doesn't kill me can only make me stronger.
Mk1 will be back.
Mk1 will be back.
Bobby
Petrol getting in to engine, (pump squirts healthly and plugs are wet)
Zeus said
Earth strap??
one thing out of everything i haven't checked! thanks
Mk1 will be back.
Mk1 will be back.
paul_c said
If it was the earth strap faulty, the starter motor wouldn't turn over quickly, which would be easily noticed.
yea that is whats happening its like it just stops and starts all the time! so is it earth strap then sounds likely??
I can't understand why you changed coil, dizzy, plugs, cleaned out the carb etc then. If the starter motor isn't turning over as it should, its going to be the battery, the starter motor or the leads/connections in between, can't be much else*.
In that case then yes - take a good look at the earth strap.
* its possible that if the ignition is too far advanced, it will make starting difficult because the engine fires and tries to turn the engine the other way at the low rpms of startup - but its easy to check this by disconnecting a lead off the coil and retrying.
