brakes?
(In Topic #113290)
brakes?
natodubz said
ok, next question…….. can i fit a golf mk2 16v servo unit? will it be of any use? i ask this cause i got it laying around
Yes, but you also need to use the matching master cylinder, or at least one which has the same depth for the plunger to go into it. In other words, NOT the Mk1 master cylinder, but the Mk2 16V one (this one is wider diameter which gives the reduced pedal stroke). The servo, being larger, means there's less force required for the equivalent braking.
The Tech Section on the left has a write up of how its done, and its a popular conversion so if you have any issues then a forum search or if you can't find what you need, a question, will sort out any issues that come up.
