Bolt on k&n for weber carb
(In Topic #122484)
There is the valve in the standard set up that regulates warm air thru the filter into the carb that stops it from icing up.. The bolt on/stack filter has none of this so I fear the carb may ice up..
Has anyone got one on their car? Must be someone.. You suffering at all from the carb icing up?
My Golf for sale…
http://www.kerbsidekustoms.com/forum/mk1-13-for-sale_topic1282.html
Rusty Hookers Dub Club
My Golf for sale…
1) warm air feed from the manifold to the airbox (removed if you fit a K&N filter)
2) exhaust gas recirculation through the inlet manifold
Our own experience of having a duff warm air inlet is that the heated manifold isn't sufficient to prevent icing - you WILL need a heated air intake as well
Run a slightly thinner diameter pipe around the engine on the other side, pickin up heat on the way then I the stack filter?
My Golf for sale…
I don't particularly like the original filter housing, bit of an eye saw!! ha ha… Don't want to smooth the bay, just want to tidy it up a bit a maybe a small dress up and re-paint… Had a few issues with an oil leak recently so going to completely degrease and re-gasket everthing…
My Golf for sale…
I want to do the same with my engine bay, clean it up - respray the metal parts and get rid of oil spills! i have already painted the majority of the metal work!
