Another problem. (Juddering at speed)
(In Topic #88733)
I'll be going along in 4th gear at 60-70 mph and suddenly the car will start juddering. Naturally I ease off the gas and the juddering stops, then I put my foot down again and 30 seconds or so later the juddering will happen again (again at 60-70mph.)
Earlier I did a longish journey on a dual carriageway and the juddering got worse to the point it wouldnt let me go about 50mph without juddering. Luckily I got to the end of the dual carriageway and back onto normal roads with a 40mph limit and all seemed well.
This has really been confusing me as I am unsure what it could be. It has brand new spark plugs, newish dizzy cap, rotor arm and points (only 350 miles old) and the points gap is correct. I have a weber 34ICH carb which has also only seen 350 miles of action (it was unused when I got it.) The car revs freely and whatever the problem is appears to be speed related rather than related to the revs.
I dont think its carb icing as it happened again today when it was 20 degrees C outside. So im guessing its a fuel problem that must be somewhere else along the line. The only other thing I thought of would be the "rust in the tank" syndrome that mk1's get. Could this be the issue?
Thanks.
mk1 1.1 C
Only you will know, I might be wrong.
Tian :dontknow:
mk1 1.1 C
good luck,
paul
i had exactly the same problem and it turned out to be busted fuel pump! it slowly got worse and then undrivable! a new one was 50 quid and then ran sweet as a nut!
James
1983 1100 C
1983 1100 C
