ahhhh please help. oil leaking everywhere
got a bit of an oil leak and i suspect its coming from the fuel pump, there is a little rubber ring/gasket inside the fuel pump and it is a bit old and broken. does anyone know where i could get a new one asap. how about gsf car parts, does anyonne know the item number. would appriaciate this very much .  :pray:
thanks alot
martin
Try the main stealer first IMO. Its the sort of thing they may have in stock and cheap!
will do, first thing.
thanks
VW part number fuel pump o-ring is 052 127 311
1983 1100 C
Did you guys even read the question?
Oil, from a fuel pump?
If theres something I don't know about carb engine fuel pumps and oil then please feel free to set me straight.
Peter.
1980 1600 GTI, daily driver.
peter,it leaks oil from where the fuel pump attatches to the block.
I dont know you GTI people  :posh:
Bert  :wink:
Thats not a rod knockin,its a diesel stupid! floppy top and 1 tin top
They what? attaches to the block.
Who's idea was that?
I'm off outta this section, too weird.
mutter mutter…
:lmao:
Bert
:lol:
… the oil can leak out when the o-ring is worn!  :angel:
1983 1100 C
lol thanks peeps. go the o ring from vw dealers this morning, fitted it, oil stoped leaking, thought yeah great. decided to go out for a drive a bit later on, and noticed black smoke coming out of the bonnet. pulled over poped the bonnet and there were flames n all sorts going on. put flames out wiv hands in a panic (not good) :banghead: . yeah so one of the lines going from the fuel pump to the carb was a bit perrished and leaked, causing the clutch cable outer skin to burn, along with many wires. oh the joy of old cars lol, could have bin alot worse but all should be good in a few days.
thanks alot
martin
Lucky escape, replace all the fuel lines to be safe!
Probably old perished hoses couldn't stand up to be moved about when you took fuel pump off. As Dubboy says replace all the fuel hoses in the engine bay to be on the safe side.
1983 1100 C
