Adjust timing belt
(In Topic #97189)
Adjust timing belt
edit. whoops your on about a small block arn't you. sorry fella not awake right now.
So do I need to loosen off my water pump a bit to slacken the belt?
Or does it need tightening?
Easiest way to find out what is squeking is to spray a bit of wd40 or such like on one component at a time until the noise stops, ok it doesn't fix the problem but at least you know where it is !
