4speed linkage
(In Topic #73458)
4speed linkage
hi, does anybody know if you can get a refurb kit for the 4 speed gear linkage? mines really wobbly and has got no feel to it whatsoeva. also does anybody know why after refitting my box the linkage seems to be sitting differently and not reaching properly? any hepl would be great, thanks.
matt
matt
The linkage is adjustable. The official procedure is to use a proper VW "gear stick centering tool" which holds the gear stick in about the right place for neutral (in the 3rd 4th plane).
Having said that - all I do is loosen everything off, get someone to sit in the car with the gearstick held about where it wants to be, tighen it all up and see how it feels.
I think Euro Car Parts od the annoying little "plastic ball" bit on the gearlinkage as this is the bit that usually breaks up - on my first Golf it got soo loose it dropped off and I had to drive 15 miles in 3rd gear!
It isn't this setup…
If this is a small block 4 speed, it is a straight rod change box - All the jiggery pokery is done inside the box, not like the Gti linkage setup.
I think the slop is probably the plastic ball at the bottom of your shifter though.
GSF website lists this which will probably contain whatever it is that is worn:
Pt No Description
71708 GEARLEVER REPAIR KIT G1 1.1 9/75 >12/83 ?4.95
71708 GEARLEVER REPAIR KIT G1 1.3 8/79 >12/83 ?4.95
Hope that helps…
My Build Thread
Oh - and they also list this, but I don't know what it is?!?
71707 GEAR LINKAGE SHIFT FINGER G1 1.1/1.3 4 Speed 81> ?15.00
My Build Thread
cool, il giv it a go. i think my clutch will be ok now steve, it was just really stiff and seems to have got better the more i use it.just all the wiring to firure out now
Wiring doesn't pose much porblem - except the temp gauge which I am still trying to work out…
There is a little "hook and ball" type thing on the end of the shift rod but there were about four versions across the lift of the Mk1. All mine have been small block ones…
Another step closer
Another step closer
yeh, feel like im getting sumwhere again with it now, sorry, i was on about the wiring for the dash and indicators and stuff. thrv all got a mind of thr own at the moment!
Indicators? Just wind the window down and give hand signals - actually you'll probably need those for the MOT!!
yeh, probly.il have a read of the electics forum.
