1983 1.3 Golf CL distributor issues!
(In Topic #119508)
I'm pretty new to watercooled VWs and have been looking around on the search function regarding the dizzy fitted to my car.
It would seem that it isnt a bosch dizzy fitted (I cant make out who makes it)
The problems I have is that first of all it sounds like a cricket on ecstasy is inside the dizzy cap. I dont like this!
The other problem is that ive read on here that a certain (non bosch dizzy) can leak oil so bad it can make the clutch slip. This is happening at the moment!
SO, what I would like to do is fit the bosch dizzy and fit an electronic ignition (pertronix 1843 i think)
Which dizzy do I need?
Thanks for your help in advance!
There's a rubber o-ring seal on the dizzy base inside the head which is usually dead. pop a new one on and they do leak less. it's just a case of popping the dizzy cap off and cleaning it out every now and again! mine leaks a little but not that bad!
Jon.
Thanks for pointing out which dizzy I have though.
the bosch version is the same only with less leaky. they still leak a bit.
Jon.
Nik
