1981 1.1 engine help!!!!
(In Topic #185044)
NO START
Chris
rans
Chris
rans
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
if you set cambelt timing to tdc and pop off the dizzy cap make sure the rotor arm is pinting at plug lead number 1 then arrange the leads counter clockwise 1-3-4-2
have you set the points too?
i'd pop out a plug see if it gets wet after cranking and see if it sparks while cranking and condition of spark.
Olly
If you're getting a strong spark and all the timing is correct then I can only think to try starting again, first tho unbolt your fuel pump from the head and draw up some fuel by hand into the carb, and then like before with a drop of fuel or easy start down the carb might get it going
'83 formel e
ned_h said
the cam timing is definitely correct? I had starting problems with mine and found the cam pulley was 1 notch out, and as Olly says make sure the the rotor arm is facing the right way when all lined up, there should be a little notch on the dizzy body if you take the cap off which'll show you roughly where it should be, could be facing directly opposite at number 4 (I'm sure you've more than doubled checked all this now tho)
Hope this helps
Goly The Golf, a 1983 5dr 1.3cl having a full resto.
GolyTheGolf said
We know that you have fitted the leads in the correct order (1-3-4-2 anti clockwise on the cap) but what side of the engine did you take as being cylinder 1? Cylinder 1 is at the camshaft sprocket end! If you have accidentally done it the other way it will cause the issues you have!
Hope this helps
Hello thank you for your reply. Yes the number 1 cylinder is set to the one closest to the timing belt and number 4 is next to the distributor.
