1300 original inlet mainfold and carb needed!
(In Topic #119585)
What doesn't kill me can only make me stronger.
Mk1 will be back.
Mk1 will be back.
wether you could use this to service the one you have?
though i must warn you, its ridiculously horrendous. the original carb was so bad i went to the trouble of getting a custom inlet manifold to fit bike carbs. every time you pull up to lights you had to pull the choke out to stop it stalling, and even a specialist couldnt get it to idle below 1200rpm. constantly cleaning carbon build up on the spark plugs.
ditch the original, even if your going for OEM, and get the webber replacement if you can source one
This is not a good town for psychedelic drugs
