1.3 on bike carbs
(In Topic #120451)
1.3 on bike carbs
This is not a good town for psychedelic drugs
Worth the journey trust me!
I'm in Norway, so it's kinda expensive to call and explain what I want (bike carbs + manifold for 1,1 engine code FA)
Maybe someone can help me?
i phoned them they were more than happy to tune the car including replacing jets if neccasary for under £100 so proper chuffed with that cheers for pointing me in their direction!
i run gsxr 600 carbs on a home made manifold main jets redrilled to 1.6mm. runs pretty good, balanced them with a small bike balancing gauge i borrowed.
excuse the wiring mess.
Olipirate, what is going on with your top mounts? Are they some sort of entended jobbies to lower your car that bit extra? Looks interesting 8)
just get a base plate cut out using a plasma cutter and get some tubes welded on in the correct spacing.
jackking said
any 1 no where i can get an inlet manifold made cheepish n not bogbrothers plz?
laser cutting for under £50 so long as you can get the CAD/CAM drawings done, got mine down at bradford college for the cost of a couple of pints
woops
I still got manni and carbs… for sale
first road test
or should i say its inability to put the revs to road is awful its redlining far too soon…i need a new perhaps closer ratio gearbox….any ideas what will/wont fit?
as far as engine and gearbox codes go for whats already fitted, i have no idea what they are, but i'll check in the mornin. i know its the very early run of 1.3 with the exhaust pre-heating the carb
