1.3 not running right
(In Topic #133366)
very sluggish, sounds like it is running on 3 cylinders and a big loss of power. ideas on what to check please?
thanks
did this The Mk1 Golf Owners Club
and when I got to this stage
to my amazement there was nothing there. no swirl pot or filter or anything, looked everywhere through the hole and found nothing but clear fuel, no flakes of rust or anything…
ideas?
by the way, does this model have a mechanical fuel pump? what else should I check?
- My petrol tank seems pretty clean and there no sign of rust, dust or flakieness on the inside, good.
- The 1.3 does have a mechanical fuel pump and it is driven from the camshaf. it can be found near the camshaft pulley.
- Unlike the GTI, as said before, the pump is not electric or placed on the tank. Also because of this is works mainly in suction, and the pickup and return points are on the fuel level sensor assembly.
- My problem is not related to fuel starvation.
So, after much fiddling with the fuel system i had the "brilliant" idea of unplugging the spark leads one by one… dohhh…
Yes, it turns out that i was(is) really only running on 3 cylinders. Cylinder number 4 for some reason is not firing. Also more intrieguing is the fact that if I remove the no4 lead and leave it close to the spark plug the spark will actually jump the gap and the engine will run/sound "fine".
So its a contact problem I suppose. I looked down the lead and inside everything seems normal. any ideas on how to improve the contact between the two? I'm actually quite happy that it seems to be a simple problem.
