1.3 GF No Cranking When Hot
(In Topic #139711)
FAULT:
After engine has been idling for a long period or after a few small journies in traffic etc, the beast fails to turn over, turn the key and can hear the relay click but just won't turn over. It does seem that I have to turn the key further these days to get to crank position? So was poss thinking possable ignition switch, but then I can hear the relay? Poss starter/wiring fault? fuse board fault?
I just thought I'd ask before I start ripping things apart, also the wire has snapped off my multimeter.
Many thanks in advance.
I've had that problem a couple of times before and both times its turned out to be the starter. They don't like getting too hot so if you're mk1 has overheated in traffic or being stood still running it does affect warm starts.
Replace the starter and try and address any cooling issues if you have any.
I havent had any starting problems since changing my setup to run without that preheat pipe so I would also imagine that you are correct with that assumption 8)
You could heat wrap it, or get rid, or numerous other options
