1.1 to skoda 1.6?
(In Topic #117128)
1.1 to skoda 1.6?
cheers matt
Assuming the skoda motor has a similar intake manifold and will take bike carbs or twin webers/su's etc then it should be good. Unless you fancy a full custom fuel injection set up.
only other thing is is what gearbox they use as it's not always compatable with the mk mounts.
Jon.
failing that option would it not be easier to put an in-line fuel pump and use the gt head on the golf 1.1 bottom end and gearbox? as you can tell ive played about with engine in the past, but im used to vauxhalls and have not long made the jump to vw
Depends on the 1.1 I suppose. I know my formel e has the high compression engine, which I'm guessing was achieved by reducing the dish in the piston, meaning the 1.1 piston's would smash the gt valves to bits?
I'm sure there will be someone on here who can be sure.
best bet would prob be the tank from a gti mated to the polo gt fuel pump which could then run the gt or skoda fuel injection. only issue would be wiring it all in, and the possible gearbox issues.
Jon.
I don't think the GT head will fit a 1.1 or 1.3, as they have the older solid lifter head, and the GT is all hydralic. It probably could be done, but wouldn't be worth it.
Personally, I'm fitting twin 40's to my 1300. :twisted:
Probably won't go any better, but it will sound nice :mrgreen:
Driver driver.
