1.1 stalling problems
(In Topic #74986)
This can be avoided if the revs are kept up with the throttle or if I pull the choke out a bit to keep the revs up. Also noted that if I try and start and it stalls and and leave it another 5 mins it will start and run fine. The problem dissappears after about 10-15 mins of driving.
I'm at a bit of a loss as to what could cause this sort of problem or where to start :dontknow: . Carb, plugs, HT's, points, condensor and coil have been replaced in last year and the problem only effects the engine when idling. Any help much appreciated.
1983 1100 C
1983 1100 C
Try the Fuel Line & the Fuel pump,
Check the points & the rotor arm once again.
Hope this solves it.
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Sounds like it might be the thing, as your engine gets re-started using the (cooler) fuel in the bowl on the carb, but then things go downhill…
Re-route the pipes, or lag them with insulating material to keep the heat away.
1983 1100 C
1983 1100 C
markwon said
Thanks, I haven't had a chance to have a proper look it, ben run off my feet welding my GTI. Am I being simplistic or is fuel vapourisation more pronounced in hotter weather? From memory the fuel pipes do run close to the head, but obviously this is necesasry to route into the pump, might lag them and take it from there.
It is more pronounced in hot weather, but can happen any time if the conditions are right. Re-starting after a few minutes can be "the right conditions".
Deep Explanation (in case you are interested):
The engine, which had been getting rid of its heat through the coolant, can't do that any more (water pump stopped with engine), so the heat that has been made just before stopping radiates & conducts out of the engine, into the air in the engine bay and into the components touching it, including the carb and fuel lines) - for a few minutes there is a big heat spike, before the whole lot begins to cool. Unfortunately, you are trying to re-start during this spike. Moving/lagging the fuel pipes will help stop some of the conduction & radiation of heat from the head into the fuel lines.
1983 1100 C
1983 1100 C
