1.1 solex carb problem/question
(In Topic #154691)
Hi all, got a few questions and issues i need addrest , went out to start her this morning and gave it half choke and one pump of the peddle as that usually starts not a problem, but didnt fire up, gave a kick aand kept birling aas if flooded, so took the carb off to see if there was any rreason behind it, it seemed tthe rubber mount between tthe carb aand the manifold was split, but once i had iit off and llooked inside it was jjust the oouter rubber tthat was burst, but found what i thaught was a leak off that wwas blocked with a pipe and a split pin, i want to know what this pipe is for and if a pipe ccomes off it were does it go , i will try and uupload piks ,thanks Steven
Chris
1982 3 Door - 'BRO' - gone to pastures new
1990 Clipper Cabriolet - Jet green metallic
The biggun is the crankcase breather, you can feel a dome shaped object most of the way down the block, this doesn't need to be attached, if you don't mind oil mist going everywhere
1983 Golf 1.3 Driver:
