1.1 GG high idle problem
(In Topic #113876)
The thing I dont understand is that sometimes it runs at 1000rpm or lower for as long as two days but then it can run for a few weeks with a high idle (sometimes up to 1400rpm) On the days it idles high it normally gets worse as the engine heats up. I also dont get much idle screw adjustment. The screw is all the way in so I cant make it run slower.
Checks I have done so far:
.Timing
.Tuned
.New carb mount fitted
.Cleaned up earth wire to carb (idled great after that so i thought it was fixed but then the next day it was runnning fast again)
.Checked the inlet manifold was tight
Im planning on checking the idle solinoid works but..
I just cant figure out why its intermittent. What could cause intermittent idle problems? As I said it can be fine for days and then go high again..not just varying idle speed on one journey..
-No water in your petrol is there dude?
-Air leaks around the inlet manifold, spray WD40, or the like around it to check for leaks.
-Atmosphere can have an impact on running (long shot)
-Sticky pre-heater flap?
DubNut said
-Intermittent idle solenoid?
Going to swap the soleoid from my spare carb over and check the mani again tomorrow.
Theres no way there can be water in the tank.
Cant be the flap as it does the same thing with the airbox off
Will.
Cheers for the help both of you
