1.1 carb help
(In Topic #125407)
1.1 carb help
Would really appriciate some photos of carbs off a 1.1 golf please ?
The vacuum pipes on mine look all over the place to say its the standard carb theres vacuum lines that have just been cut and blocked off this cant be right! mines one of the last year of mk1's made if tht makes a difference to the carb?
Or failing that if no one has any photos does anyone have a vacuum hose diagram for the carb? cheers guys
hey man,
mines an '81, so if i'm reading haynes right the carb will be the same. i'll grab a pic for you after tea
Cheers clump I would really appreciate that! yeah mines a '83 so im sure they'll be the same carb
yeah by after tea i meant tomorrow, anyway here you go;
basically one to the vacuum advance on the dizzy, the other to the warm/cold air intake setup on the airfilter box.
whereabouts in nottingham are you btw?
Cheers dude, appreciate the help just realised i've got a different exhaust manifold on my car and cuz of that they've taken the end off the air filter where one of the vacuum lines goes too but that doesnt explain why ive still got one other line blanked off! I'll take photos of mine and see if we can compare lol
I live in sandiacre which is pretty much J25 of the M1 where abouts are you from?
Those vacuum lines just operate the warm/cold air intake mech, so if you've not got that anymore I wouldn't worry about it. Any running problems? It's supposed to help cold starts but I never noticed a difference without it tbh.
Ah nvm, I'm from stoke, I just go to uni there and i always see a well low mk1 around derby road. It annoys me cause i can't work on mine while i'm there
I did used to drive into the centre of notts every day for college, mines a red tin top?
It doesn't idle very well at all, its quite lumpy, changed the points and condensor and it pulls better now once u have the revs up but still doesnt like idling. I think its just a mixute of lots of littles bits need sorting, had mot today and it passed but the guy said hydro carbons are quite high which would suggest its running lean and it does have quite a wiff of petrol haha
but you can't touch the mixture screw as soon as u make quarter a turn either way it just splutters and cuts out
yeah dark red, black wheels?
Ah see I'm not that familar with carbs yet. Mine had a similar problem, adjusted the ignition timing and idle speed screw on the carb and it's much better now (not quite perfect though). Maybe check those too?
Good stuff on the MOT pass though, dreading what'll come up in mine. just been stripping the braking system down in the rain, great fun :roll:
Mines dark red yeah but with blue wheels :s they are quite dark tho so could of bin me still, not seen many other red mk1's around notts lol mines got no bumpers if tht helps? lol
Yeah cant imagine that was much fun! its not actually rained here yet today, rite so he's what i have on my carb, theres one pipe on the back going no where….
and then another one on the choke side of the carb going no where…
I have no vacuum lines going directly from the carb to the distributor, the vacuum line going to the dizzy splits off from the main pipe from the inlet manifold to the brake servo through a t piece. tht sound a bout right?
hey sedge, the first photo is fine. thats just the warm air vac. if you dont have the warm air feed pipe dont worry about that one.
however…
the second one should have a pipe going to the distributor…
on the top of the dizzy there shouldbe a round disc with a pipe on the top?
if you have this then you should go get some vac hose and join that hole to this piece.
unless you have a form of electric ignition that doesnt need vac advance??
any way yeah, if you stick this on you may find the car runs much better up higher in the revs.
thumbs up all round
however…
thumbs up all round
booze and boredom, the greatest mix
yeah ive got tht on the dizzy, the pipe thats on the dizzy at the moment goes to a t piece between the green like reservoir bottle and the pipe tht goes from the inlet manifold to the brake servo!
Does this need changing round then?
green bottle???
lol
um well im not quite sure of that setup… get an engine bay pic and ill see what you mean… lol
you should have a 10mm pipe coming off the manifold and going to the brake servo with a non return valve on it, an then the pipe form the dizzy going to the carb.
i think the vac is alot stronger on the servo coming from the manifold than from the small inlet on the side of the carb
lol
Sorry took a while to reply had a busy day! this is the set up my car is somehow running on at the moment all be it not running that well! cuts out when ever i just leave it to idle
right… that green pot is some sort of expansion pot.. you dont need it
then remove all the hoses lol.
take off the rubber t piece and put the non return valve back on the rubber bit going to the manifold.
then take the long pipe coming from the distributor and put it onto the nipple shown in the second image above.
so you have no t pieces and no green bottle..
try that
oh also…
i noticed some residue on the ali base plate in one of the earlier pics.. this looks like mine when my rubber gasket was letting fuel and air out.. take the air filter off and move the carb slightly, while doing it look around the gasket and see if it separates from the base plate or carb, if it does and you see liquid in there then you got a leaking gasket, this will be another reason why it can run like crap
im having exactly the same problem at the mo… mine wont idol for shit.. i know mines the gasket but i cant get it till after the agm… that should be a fun drive up.. lol
hope some of this helps…
if you dont understand some of my gibberish ill take some photos tomorrow after work an let you match it up
try that
oh also…
The green bottle is a vacuum reservoir, used to operate vacuum capsules and pull down mechanisms, on yours it would have supplied a reserve of vacuum to operate the heater flap in the air cleaner intake- however if youve not got it any longer youll not need it.
What youve got there is a dizzy thats having full vac advance pulled at idle and most of the way up the rev range due to the piping being wrong.
Does it "pink " at all?
Although some carbs do have the vacuum piped to the dizzy in that manner, they usually have a retard capsule fitted to the other side of the diaphragm on the vac advance so the correct advance curve is gained.
Carb looks like an old solex on that one photo so it only has the port for the one vacuum line.
Pipe the vacuum to the dizzy to the carb directly and blank off the vaccum port from the servo as you want the carb to actuate the vac advance capsule as the revs alter, not to have it pulled full on all the time.
Cheers mixerman ur a legend! I'll have a go at tht tomorrow. When I've got some time off work! Is gsf the place to go for the carb gasket and non return valve then?
i assume so..
i got my gasket off crazyquiffs. your non return valve should still be fine to use mate, just pull the rubber t pipe off it and but the old pipe round with the jubilee clip on it. job done
im thinking of getting a ali carb mount made up for mine as i dont have the standard air box on and mine wobbles like crazy… if i get one made and they work well ill see if i can start banging them out with a gasket set to make the carb more stable
hope you get it all sorted. ill keep my eye on this throughout the day as my boss is on holiday so i can pop on here
ill get them pics just after 6 an ill pop them up about 7. i got some tinkering to do any way.. im getting bored of it not idoling properly
are you taking it to the agm??
Cheers dude, I'll have a look on crazyquiffs then :-) I'm sure I no what you mean now but won't get chance to have a play until Saturday morning now so I'll post up then after I've rearranged the pipes :-) appriciate the help tho cheers!
I don't think I will be at the agm, a load of mates are going down to bugjam as they've all got different dubs so I think I'll be heading down there with them instead of being a loner and coming agm as much as i'd love to go! :/
Not sure how much longer I'm gonna have the 1.1 in my car if everything goes to plan could only be a month or so!:-) but will still be interesting to see if ur mounting plate idea works :-)
ahh yeah, hows the leg? i remember readin about it now i think…
getting your 1.4 in there from the mk3 soon then
im working on sat but i get reply emails to my phone lol, ill try and keep my eye on it just incase ya get stuck lol.
my leg? think ur thinking of someone else there, mine are both fine thanks
hopefully just trying to convince a mate that it'll be a good idea to help me as he's a lorry mechanic and has all the tools you could ever think of pretty much but also used to work for vw few years ago haha and where as my tool selections consists of THE very basic scoket set you could imagine and a set of screwdrivers haha
