1.1 c clock - GTI clocks - MOT
(In Topic #73497)
Im nearly there with my car for its mot now so but there one thing i need. I dont have any clocks that work so im looking for a new cluster. I've been searching for the 1.1c clocks with no rev counter but these are well hard to find!!! I was woundering if the gti clocks are a straight swap ie wireing etc. I know the rev and mfa wont work but will this fail the mot come mot time?
cheers. low'
cheers. low'
1272 driver with a magic tree!!
Life Member
The rev counter only needs a feed from the coil to work I believe, unless any one else knows otherwise. Should be simple to get it working. I remember putting some GL clocks into my wife 1.1c many moons ago…
Cheers,
Drew.
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
Speedo is not part of a Class IV MOT.
I have a set of working 1.1c clocks for sale -showing 65k. if you're interested send me a PM.
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
changed my 1.1c clocks for GLS ones, i think. It was a case of plug 'n' play. rev counter worked first time.
yeah sorry, should have said, GTi clocks plugged in and worked fine . No need to run a coil wire . .
'83 Mars Red 1.1 C
If you put GTi clocks into a 1.1c does anyone know if the speedo will be out?
I assumed 1.3 driver clocks would be the best way to get a rev counter in my 1.1c (with a 1.3 HK engine). Anyone know if this is right?
Thanks,
h
Thanks,
h
the speedo will be fine, unless you've got tiny or massively oversized wheels on !!!
Real golfers don't play with clubs
Yup - 1.3 Mk1 Driver clocks would definately be the way to go.
Not sure about the speedo issue - Iv'e just chucked an 1100 'box in mine and it has a buzzier diff ratio so I'll see if the speedo is now out…
