wont select reverse
(In Topic #73684)
wont select reverse
hi, my 1.3 4speed will not select reverse. any ideas?? :dontknow:
1 to 4 work fine but reverse wont select. its all tight, i had to take the selector off when i changed the box and iv been trying to set it up but it just wont get reverse. when in gear it there isnt much play in the linkage.
Ahh - In that case it's should just be adjustement. Take the selector of the spline that come from the gearstick. Put the box in neutral and position the gearstick in neutral between 3rd and 4th. Then slide the arm back on the shaft. You may still need to adjust a spline or two.
thanks, il giv it a go.
