wind back caliper
(In Topic #111993)
wind back caliper
Or if really stuck you can move it back but using something to lever pressure onto it. But be careful if doing it that way to not damage the caliper and ensure it goes back in evenly.
Most calipers that need wind back tools are rear calipers, which rotate as they come out. Normally on more modern cars.
Apols if I have misunderstood.
1988 1.8 carb Golf Clipper
I shall try that.
They are 16v calipers
Twitter Manager
if you mean rear calipers pushing the piston in with a g clamp or whatever will trash the handbrake mech, you need the proper windback tool in this case.
You do not need to do anything else unless you plan on changing fluid also
Pete :wink:
