Which Driveshafts 1.3-1.8 conversion...
(In Topic #77172)
What needs to be done for the drive shafts?
We have MK2 big block shafts, and the MK1 small block shafts..
TT
TT
Mk2 shafts definately wont fit, they are too long and have different sized joints.
I have gone from a 1.3 4 speed - 1.8 5 speed, using a 1600 GTI 020 and it would seem that the n/s 1.3 driveshaft is a bit too long, as I have a problem with not being able to achieve any kind of negative camber. The o/s however, seems fine.
Anyone else?
TT
If you wanted to use a Mk2 16v gearbox, you could use Mk1 Cabriolet driveshafts as these have the correct inner 100mm CV's and are the right length.
You could bolt up your 1.3 shafts to the gearbox but like I say, I'm having trouble adjusting the camber on the n/s with this shaft.
Looks like I need to get me some cabby driveshafts then!
Looks like we both need MK1 5SP GTI shafts…
TT
Guest user
twinturbo said
Your box is an 8V! So supposedly 90mm flanges..
TT
oh yeah, sorry misread that post, so Mark 1 5 speed driveshafts it is then.
Storm, I'm gonna double check the measurements on my gearbox and then will drop you a pm.
thanks.
