Wheel offsets - MK1
(In Topic #87962)
Wheel offsets - MK1
I am looking at a set of 7x15 4x100 ET25 Borbet A alloys at the moment.
HAving discussed this with a few people some say they will rub and that a min of 30 ET can only be used and some say they will be fine :dontknow:
What are the do's and don'ts of alloys on a MK1 in terms of sizes in particular offsets.
Has anyone got Borbets or alloys similar to the above in terms of size already on their MK1 and how are things working out?
Thanks.
MK1 Golf Gti - Mars Red Campaign / MK2 Golf Rallye SE/ MK2 Golf Gti - Black 16v (small bumper) / Corrado - Red G60 / Porsche 911 (Daily)
2.0 16V
offsets
Seems to be more trouble that its worth but can anyone comment for definite on what is the guideline?
Touch my donkey! I shoot you with my gun
Re: offsets
13/14/15/16" isn't really the issue so much as the rolling radius, tyre width and offset. suspension set up will make a bit of difference.MikeGTi said
These are 15" though and an extra 5mm of ET.
what 'guideline' are you on about?
i'll give you one,
to absolutely minimising the possibility of rubbing, stick to standard offset, rolling radius and tyre width.
personally, i'd go no lower than et33 and no wider tyre than 205 (though not this combination) and always try to keep rolling radius as factory intended. an et 35-38 with 195/50/15's should give minimal chance of rubbing.
offset
33 et it is as I could not be bothered ruining my motor by cutting arches etc.
im currently running 15 x 6.5J BBS RJ wheels on my mk1 golf
these are ET33 running 195/50/15 tyres…
the car is sitting on FK konigsports and lowered a fairly reasonable amount, i have had to rock some negative camber on both wheels to stop rubbing on the arches.
Smaller tyres are definatly the way forward, 175/45 if they made them would be a far better option…
also the arch lip does need cutting and folding as that will give you an extra few mm's
i get big rubbing off the arch over potholes and very enthusiatic cornering which puts me off, im looking at getting 175/40 or 45 for my new 15x7 ET30 wheels coming this weekend or next week as i will definatly need teh extra room
and before any says raise the coilies… its not gonna happen
