wheel/hub nut and bearings problem
(In Topic #79575)
I replaced my front wheel bearings
on my mk1 '81. When i thightened the
nut, which is on the end of the CV joint
i can't spin the wheel. I took the jack off,
drove few meters and jack the car once
more and the wheel is spinning without
problem. Is that normal? I know structure
of this kind of bearings but i don't think
it should be this way.
Any suggestions?
BTW, i'm new member, so i wrote some
greetings on proper section of this forum
Kanclerz
Kawa VN750
Golf Mk1 '81 1.6d
Kawa VN750
Golf Mk1 '81 1.6d
So many dubs so little time, so much rust
that i overtightened them. Only if in golf mk1
this nut is thigtened by another moment than
in golf mk2. I used service manual for golf mk2,
because i don't have it for mk1.
Kanclerz
Kawa VN750
Golf Mk1 '81 1.6d
Kawa VN750
Golf Mk1 '81 1.6d
Regards Volkswarren
it and it seems to be ok. I compared it to my old
cv joint and data in the mk2 book. I know, that mk2
has slightly different outer diameter of cv joints.
But my new cv joint has good outer diameter.
I cannot see any destruction on inner surface of
hub which may comes from cv joint. I'm driving
my mk1 now, and i can't see any problems, but
i want to know that this problem doesn't cause
bearing failure or something like this.
Now, when i jack up my car - the wheel is spinning
without any problems.
Kanclerz
Kawa VN750
Golf Mk1 '81 1.6d
Kawa VN750
Golf Mk1 '81 1.6d
