What lenght should wheel nuts be?
(In Topic #134216)
Om my car the standard nuts are 4cm long and the locking ones are 2.5 cm long.
One of the locking nuts has lost some of its thread and I acnt tighten it up and all of the locking nuts dont seem to tighten that well only needing two turns compared to a lot more on the standrad nuts.
looking on e-bay all the locking nuts avaialable for mk1 golfs are 2.5cm long
Any help advice appreciated?
1992 clipper
T5.1 Caravelle
T5.1 Caravelle
You need a solid eight turns.
T
T
If that's your car on your thread up there… It would appear that they are bbs ra? I would stand corrected. I have ra's on mine and my wheel bolts are 38mm long as the ra's have a deeper flange on them. I don't know why. Better quality i guess. My locking wheel nut is 35mm long. And the as above a good eight turns will see it on nice. I was told six was adequate by camskill. But more the better. Also… Make sure you have the correct head. Bbs ra are 60degree radius seat. Not the usual 60degrees. They are like a mushroom head… Hope this helps.
Thanks thats really helpful yes you are right about the wheels looking through previous posts I realised that I should have put that info in the original thread.
1992 clipper
T5.1 Caravelle
T5.1 Caravelle
std VW alloy wheel bolts have 23.5mm thread on them, and all vag alloy/steel wheels are ball seating. its aftermarket wheels that have taper seating
