what drive shafts do i need please help
(In Topic #95315)
chudd said
new acd gear box
Not sure what this is ?
Cheers……….
ACD is Mk2 Golf GTI 85-89. Thing is though, if its already in a Mk1, you can't tell (unless you measure them!) if the flanges have been swapped to 90mm already, in which case you'd be okay with stock driveshafts. Also, bear in mind that when we talk about 90mm or 100mm flanges, they're not the industry standard measurement (distance between bolt centres) but the outer diameter of the CVJ/inner dia of the flange lip.
