What box
(In Topic #146592)
What box
A MK2 Golf 1.6/1.8 CL/GL gearbox gives @25mph @1000rpm, or put the 1.8 8v DX engine back and get @40mpg.
Early-1800 said
What economy are you expecting from a perfromance 2 litre petrol engine fuelled by 19th century technology carburettors?
My 2 litre 16V, albeit fuel injection, achieved the same fuel economy as the engine it replaced (1.8 litre 8V fuel injection) and changing from a 1.8 box to a 1.6 box (lower geared) didn't make much/any difference to the fuel economy either.
Carbs - I've not used them myself but possibly if they're set up properly, shouldn't be THAT far behind fuel injection for fuel economy.
But….without solid info (sorry to have to ask twice for an actual fuel consumption number) we don't know it its just at the low end of efficient, or possible there's a fault. For example if there's 2 carbs and they're out of balance, one might be too rich and the other too lean, etc etc. Or there might be excessive bypass of the fuel into the exhaust. What ignition system does it use?
, obviously i know im not going to be getting 40mpg from my current engine other wise i would not have swapped it.
Gear Up!
you can swap the 5th gear with the gearbox still on the car if you like
