Very Loud bang over bumps
(In Topic #77586)
I have a 86 cabrio, which has been lowered by about 40mm. I didnt get it lowered, it was lowered when I got it.
Well when I drive over certain potholes (not necessarily just big ones, but there usually the worst) there is a really REALLY loud bang. To me it sounds like the suspension is bottoming out, but thats just what it sounds like, I have no idea what it is really.
Its far more likely to happen when the car is full of people (extra wieght) and it seems to have got worse recently.
Has anyone any ideas what it might be? My shockers are not too badly worn they seem ok, though they are quite old.
Only other peice of info, which may be relelvant is that I've had to change the bottom ball joint twice in two years… but obvioulsy that could be anything.
All advice is welcom and appreciated
Lindon
Easy to replace ?10 is per side I think.
Hope this helps
J
Life Member
Dan
You will still get a good bang with good bumpstops - you can cut them down so that you have a bit more travel.
Things to check:
Top mount condition
Bump stop condition
Shocker condition
None of this lot is expensive to get parts - if you end up changing shocks VW do the whole leg for about ?35
I'll have a look, see whats what,
you're a very helpful bunch!
Lindon
How do I check the bump stops?
Jay
1990 - MK1 GOLF CADDY PICKUP | 1980 - MINI GT 1275 | 2005 - RENAULT TRAFIC CAMPER
Jay
http://www.declangrady.com/gti/technical/front_strut_diagram.png
They are made of a type of rubber and sit around the piston stoping the suspension 'bottoming' out.
You might have a plastic cup cover sitting over them. (its a wheel off joby)
Gd luck.
<a><img></a>
Jsy
Jay
Jay
jayjay31 said
Could this course the loud bang when going over pot hole though ?
Yes, as if the 'bump stop' has perished theres just bump and no stop :wink:
<a><img></a>
Jay
Jay
top mounts, shocks, ball joints, swing arm mounts is the route i'd take to checking.
get the wheels of the floor on axle stands. move them in the vertical plane and feel for movement, now do the same from side to side, while it's in the air look for oil round the stanchion of the shock and broken springs (very common) if there isn't any unusual movement then do the shock test as mentioned by rubjonny, then with the wheels on the floor look for a gap between the rubber and metal of the upper mount, while your there check the top bolts are tight and that the mounts are tight on the body to mount bolts.
