vented disks 239mm??
(In Topic #130833)
i would like to know if i can put vented disks in my existing brakes, which are 239mm (not vented), my car is the 1300 LS model, but i have put a 1800 8V motor. Will these brakes be reliable? I dont wish to spent money know in order to get bigger brakes.
Thank you.
have you got a parts supplier were you could check the thickness of the different combinations before you buy?
Saab 93 diesel daily
06 Audi A3 (Wifes daily)
only other potential problem is the flexi lines, some of the very late vags may have banjo fittings. start by changing the servo for mk2 1.8 9" servo and fit a late 16v/g60 22mm master cylinder.
That should improve the brakes a fair bit. there is nothing wrong with the vented 239mm setup they do work well, but only if the rest of the system is setup properly. make sure the crossbar doesnt have too much slack (you need a bit as when thing heat up they expand)
In order to make it clear, the calipers which will write on VWII are the ones that have dimension 239mm and are vented? Can i change the servo with the one that wore the gti 9'' and the master cylinder with a 22 one?
Thank you,
servo use mk2 9", all 1.8 models had em regardless. suitable one is also found on corrado and passat b3/4. abs ones still fit too, just have extra sensor on servo which you leave unplugged. 22mm master cylinder from g60 mk2 and late 16v then goes straight on, just buy this new as its cheap. any mk2 fluid reservoir then pops right onto it
