Vauxhall front brake upgrade
(In Topic #136593)
Problem is I have the later vectra calipers so when I have bolted everything up there is 20mm of pad poking over the disc. Could I fit g60 280mm discs and sell my new drilled & grooved ones or will I have to source some early vectra or cav calipers & use my discs?
Would rather jump to 280 though!
R18
8M
FN 57/25
Does this help? Let me know ASAP if you can as I have no brakes now!
Cheers Rob
Basically, you either need to get the right calipers for 256mm brakes, or fit 280mm discs. Bear in mind your wheels might foul if you keep the calipers you now have, its probably the same as G60 stuff - ie only certain 15" wheels will fit over (check for Corrado fitment - if they say they'll fit Corrado, they'll probably be okay over Vauxhall 280mm calipers).
Thanx M8! :wink:
Now I have two sets of drilled & grooved discs that's no use, will have to find either g60 items or early vectra calipers for the 256mm discs.
If anyone has anything let me know.
Cheers Rob
