Vauxhall caliper upgrade with 256mm discs.
(In Topic #126016)
The vauxhall calipers were designed for use with discs of a minimum thickness of 22mm, and the VW discs are 20mm when new. The Vauxhall discs designed for use with the calipers were 24mm. Would this not be an issue if the pads wore completely down?? Could there not be a risk of the brakes failing, with the pistons coming all the way out?? The caliper opening is 8mm more than that of the VW.
My web site
Jon`s Dad
I am fitting the same calipers, and have just realised that my goodridge hoses don't fit! can u direct me tho whoever made your flexi's?
Also; who made your shoulder bolts?
Cheers, and good work.
She needs PREMIUM DUDE, PREEEMIUMMMM, DUUUUDE!!!!
