Urgent advice on best place for some parts i need please
(In Topic #142827)
Front top mounts
Do i also need the "bearing" mentioned on sites if i am fitting the KW V3's?
Two bolts & nuts that hold each front suspension to carriers (obsolete at vw)
One nut & bolt that hold each rear suspension at the bottom (vw stock them but if anyone has them that also do the ones above i will get them there same time)
Rear top suspension bushes that go either side of the chassis.
Pic taken from guide on here of parts i need:
any help and advice appreciated
mike
Rich
1.8T CABBY
1.8T CABBY
only bit i need now is one nut/bolt for the lower front strut, i have the camber adjust ones.
Is this the bolt i need?
http://www.vwheritage.…32_lang_EN_country_GB.htm
Seems crazy money for a bolt?
