Trouble Finding Correct Gearbox. Help!!
(In Topic #152726)
She has had the BAM engine conversion from the Ibiza Cupra. My diff has practically exploded, so me and my friend are currently working on getting her roadworthy again.
The engine conversion was carried out by the Phirm under the previous owner. When asking the previous owner on what to fit, he said the box was a VR6.
So £80 later, and the VR6 box does not fit.
I did some ringing around and get told either a MK3 16v box, or a G60 box would fit.
I brought this http://www.ebay.co.uk/itm/MK3-golf-gti-2-0-16v-gear-box-100-working-corrado-g60-1-8T-conversion-/261175871104?ssPageName=ADME:L:OC:GB:3160 and still no joy. It won't fit!!
Some one has told me to find a CRU2014 gearbox, but it don't seem to exist.
Any actual real answers on what I should buy next? I wanna be out in the nice weather we are currently having!!
(I have a lot of gearboxes now :s)
Thanks, Jam.
Jam!!
what it could be is you have an 020 gearbox, which would explain why the diff has eaten itself.
pics?
Apparently the diff on the box in the ebay link is too wide/long?
I'll try get some photo's up later on.
I just need the correct box, then she will be roadworthy in 2 hours….
Jam!!
Jam!!
PM if you are interested
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
Jam!!
Anyone think this will defiantly fit? I can't be doing with spending more money on gearboxes which may not fit.
I've phoned the phirm, who did the engine conversion, but they don't supply parts, so that option has gone out the window. Unless anyone know of a specialist who will supply and fit a gearbox for me…..
Jam!!
Are you 100% it will fit?
This is my final attempt. I don't actually know what I'll do if I can't get a gear box!!
I've had so much misinformation I'm starting to loose faith Haha.
Cheers for the help anyway guys. I really really do appreciate it =)
Jam!!
email them direct to me if you have nowhere to upload, my username @lineone.net
so yes, any 02a or 02j will fit perfectly. measure your driveshaft flanges though, make sure they're 100mm. if they're 90mm then you have a set of rare as hell 90mm flanges off early passat, this could be why its been a struggle! the flanges should swap over though. if they're 108mm, then somethign has been dont to your shafts to accept mk4 golf 108mm CVs, or some kind of other jiggery pokery has happened
