tightned the wheel bearing up to far...
(In Topic #97468)
tightned it up to far and on the way to gti spring festival it munched the stub axle to pieces.
I took the stub axle bolt off with a huge breaker bar and it just munched it to pieces because the nut welded itself onto the axel.
what do I do no?
what do I need to replace?
can I fit a mk2 rear beam?
any help appreciated!
what do I do no?
it happened to me once, so i took the wheel off, and attacked the end of the axle with a grinder to get it all out.
needed a new stub, bearing and drum.
mk2 beam won't fit
mk2 beam won't fit
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
where can I get the stub and the drum from?
how do I change the stub though?
did zou mean you just grinded the stub off? 8O
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
thanks for all the usefull info!
one question is, is the stub axle just bolted on?
yes mate, 4 bolts if i remember rightly
spray the f4 the bolts and let soak for a bit as they have probaly been there since year dot
