Tie Rod End
(In Topic #124964)
Tie Rod End
Changing the front wheel bearings on my 1.1 Golf and the tie rod end on the N/S will not disconnect from the wheel housing. Is there anyway to remove this easily?
N3RD
N3RD
Driver driver.
I speak from experience as i've knacked a couple before, then I got older and wiser and bought a proper lever type splitter.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
http://www.charliesdirect.co.uk/products/draper-ball-joint-splitter
N3RD
Recently bought one of these and it worked perfectly. Just make sure the nut is left on but unscrewed half way so the bolt sits inside it and cant slip off.
But if it did fail pour boiling water on it. Works on almost all stuck things
the scissor type was successfull where the other one failed. I guess there are varying quality tools out there, the scissor type one I got from Halfords and its done me proud for years.
funk: I tried that too, didnt work. well, not the water part but the hammer part, leverage etc. i hammered it on the sides, top, bottom frontm rear etc nothing worked it was proper stuck in there.
